NI 9264 to produce 3 phase waveforms and shown in 1 chart
Hi Richard,
richard.tiatco@sandc.com wrote:
Do I put the "0" on the time out terminal?
Let's think about it!
The question was: "How do I ouput a zero at the shutdown stage of my program?" and I showed you how to output a zero for an AO channel.
Now you are asking "Should I wire a zero to the timeout input of the DAQmxWrite function?"
What should be the purpose of setting a timeout to zero when you want to output a waveform containing (atleast) a "0" sample???
I guess you can give the answer yourself…
Message 51 of 58
(1,052 Views)
Thanks GerdW!
For now, I have a different priority.
I need to input two different values for two different test scenarios:
1. Test Scenario 1 - 6.2V Amplitude
2. Test Scenario 2 - 7 V Amplitude
Do I need to copy paste and just switch between programs or can I use single program and perform both without changing the amplitude of all channels one by one which is time consuming?
Thanks for all your help!
Message 52 of 58
(1,034 Views)
Hi Richard,
Why do you want to duplicate code when all you need to change is a single scalar constant?
I recommend to use a boolean control and a Select node - as long as there are only exactly two cases (KISS)…
Message 53 of 58
(1,023 Views)
The easiest way is to keep the code you already have and have a control to select the test scenario you have, changing the amplitude only.
Now it depends on how you want to interact with the code. Does it run from the front panel with user interaction ? Is this going to be automated ? Like running scenario 1 then after a while scenario 2 without user intervention...
Now you need to give more details of the big picture of your project. We've been helping you to implement the basic function. But the way you implement depends on what your application will look like.
Message 54 of 58
(1,010 Views)
Thanks LVninja for replying back! Finally!
The code runs from the front panel with user interaction.
This is how the test process will run for each Equipment:
1. User will select the required amplitude value for Test 1 from the front panel.
2. User will press "Start" from the front panel.
3. User will check some parameters on the Equipment software (say <1minute)
4. User will press "Stop" from the front panel.
5. User will select the required amplitude value for Test 2 from the front panel.
6. User will press "Start" from the front panel.
7. User will check some parameters on the Equipment software (say <1minute)
8. User will press "Stop" from the front panel.
My requirements now are:
1. To put "Start" button on the code.
2. To create a logic for a selector to change the amplitude only. All other values stay the same for both Tests 1 & 2.
Thank you ALL for your help.
Message 55 of 58
(1,004 Views)
Thank you for clarifying.
In this case you can Have a Enum where you can define Test 1 and Test 2, the code will be connected to a case that will select 6.7 or 7 according to your spec.
Now to implement the code as you described,
one simple way  would be to create a state machine , check the example "State Machine Fundamentals"
In your case you will have
Init State - Setup then goes to Idle
Idle - Wait for user intervention.
Start - Begin generating waveform and then Wait for STOP
Stop - > Goes back to Idle
Quit - Stops the program.
A more "sophisticated approach would be Queue Message Handler.
Message 56 of 58
(992 Views)
Thanks LVninja!
I will do what I can and let you know.
Message 57 of 58
(987 Views)
Message 58 of 58
(975 Views)
