03-04-2016 09:48 AM
Hello!
I want to measure a rotational signal with the NI9401 and cRIO 9082. For testing i am using a signal generator and it is connected to Mod5/DIO0. In the FPGA I want to measure the rising edges. (see attached picture) With them I would be able to calculate the rpm. But my code doesn't work: The counter counts up constantly even I have no signal generator connected. What is the problem?
Thank you in advance.
Best regards
Franz
Solved! Go to Solution.
03-04-2016
10:47 AM
- last edited on
10-14-2025
01:35 PM
by
Content Cleaner
Here is a good design document that may help.
Figure 3 in the above white paper, uses the FPGA clock to determine the time between digital input events. This is not a counter example, it simply uses the DIO to give the current state of the line.
Further down the white paper is a conversion VI to RPM.
Hope this helps.
03-05-2016
05:06 PM
- last edited on
10-14-2025
01:35 PM
by
Content Cleaner
Hello!
Thank you for your answer. I have tried it and it works, but only with an analog signal. but i have an digital one... Now i found an interesting tutorial (Point 4): https://www.ni.com/en/shop/compactrio/do-more-with-labview-fpga---c-series-digital-modules-using-com...
There they wrote, that i can find the example in the example finder under Hardware Input and Output >> CompactRIO >> FPGA Fundamentals >> Counters >> Frequency Measurement >> Count and Period – cRIO.lvproj., but in my labview version (2015) I can't find this example. Do you have an idea where I can download it?
Franz
03-07-2016 01:04 AM
Hi Franz,
I didnt find the examples in LabVIEW version 2013, but in 2012 you can find them. In general you could just download the version as a evaluation and get the examples. Since I found the examples in a VM youc an find the examples attached to this post.
Besides that most examples are a restructured in the newer LabVIEW versions but the general topics are still there.
Christoph
03-07-2016 04:17 AM
Hello!
Thank you very much - it works ![]()
Now I'm able to measure the rotational speed.
best regards
Franz
