maximum position
Hey guys, how can I find the maximum position in the correlogram, i.e., at -0.0498047s? I try to use "array max and min" but unfortunaly it gives the maximum position in other format. Capture.JPG
(4,592 Views)
What do you mean by "other format"?
Array max and min will give you the maximum and mininum values, and the indices they occur at.  Use that information with the cluster of data that is into the chart.
(4,573 Views)
The correlogram is wired to an xy graph (looks like a cluster with an x and y array). Once you find the max y, you can find the corresponding x value by indexing the same position in the x array Can you attach your VI?
(4,552 Views)
Hi
(4,539 Views)
Try something like the attached.... modify as needed.
(4,522 Views)
thanks for helping...RavensFan and altenbach... 😃
(4,494 Views)
