NI 9401 counter/digital input/output
I am a beginner in national instrument product and labview. I bought a NI 9401 and a cDAQ 9174 chassis for my project. Sorry to ask this question but I am really confused about the counter and digital usage of NI 9401. It has 8 channel DIO 0 to 7. Does that means it has 8 counters as well? Can I wire 8 5V TTL signals into all the input terminal DIO 0 to 7?
I am looking forward to the replies.
(4,974 Views)
You can wire 5 V TTL signals into all of the terminals, but in order to clock any of them against the timebase as a counter you will be limited by the fact you're using cDAQ rather than cRIO.
From memory you only ever used to be able to create two counters for a 9401 in a cDAQ chassis, but I believe the newer ones (like yours) should allow you to configure up to four, depending on how you're trying to use them.
CLA
(4,965 Views)
Thank you very much!
I have another question. I wanted to mesure the frequency of a 5V TTL pulse signal with a constant fix sample rate. To do that, I tried CI Freq for a DAQmx Create Channel followed by a DAQmx Timing.  I was able to get the frequency value from a DAQmx Read in a while loop by configuring "Implicit" on the DAQmx Timing function. But the sample rate is not constant. I then switched to "sample clock" on the DAQmx Timing function.
My question is which external sample clock source should I select? I kept getting error for every sample clock that I tried in the drop down list.
Please help me.
(4,951 Views)
I'm able to drive DIO lines using the counter, but that cuts my maximum clock rate in half and requires an extra step in the code. Is there a way to directly route the Counter output through a DIO pin?
(4,689 Views)
