NI 9503 Stepper motor drive without Softmotion
We have a NI 9503 stepper motor drive and a C-RIO chassis. All the examples I found online use NI 9503 with the Softmotion module for micro-stepping control. I wonder if I can still use NI 9503 without the Softmotion module for regular stepper motor (e.g. wave drive) control? In addition, is LabVIEW 2022 (on my computer) backward compatible with SoftMotion 2020 (the latest version)?
(1,741 Views)
See if this post helps - https://forums.ni.com/t5/LabVIEW/FPGA-NI-9503-Motor-Stepping-without-NI-Motion/td-p/3302790
Santhosh
Soliton Technologies
(1,717 Views)
Thank you for the link. It seems that getting the NI 9503 working without the SoftMotion addon is very difficult.
(1,701 Views)
Yes, the 9503 hardware has to be used with SoftMotion, unfortunately both are obsolete.  NI does not support these products anymore.
For controlling stepper drives from your CompactRIO, you can check out this solution:
https://geco-lv.com/geco-motion.html
(1,659 Views)
