NI 9871 Connection from Another RT cRIO
getting error -1073807192 (VISA: (Hex 0xBFFF00A8) Access to the resource or remote machine is denied. This is due to lack of sufficient privileges for the current user or machine.) when accessing serial port/resource on second cRIO chassis with NI-9871.
Accessing the port from desktop PC works fine.
I have checked and all the settings in NI-MAX, installed latest NI-VISA Server on both chassis.
Can see the ports in NI-MAX.
Both chassis in scan-mode.
Have checked NI-VISA Server permissions, even added individual IP addresses, even tried new users.
See snapshots below:
NI-MAX ConfigNI-MAX ConfigLabVIEW ErrorLabVIEW Error
Any help appreciated.
Peter.
(3,218 Views)
What do you have on your cRIO-9066? What's the setup like? Can you send instructions from a test panel on VISA? In the constant to select the resource what else do you see?
Regards
(3,172 Views)
Thank you for the reply, below are snapshots with details.
In short, the four com ports from NI-9147 show in MAX but not in the VISA test panel or the LabVIEW diagram (had to type in the address and resource name manually).VISA-list.png
(3,156 Views)
Accepted by topic author planc
Problem solved, access/permission granted!
Here is how to fix the -1073807192 error when accessing second cRIO from cRIO over one Ethernet:
I have reconfigured everything to the second local network (second Ethernet card in my PC) 169.254.0.x.
Manually edited /etc/hosts on both cRIOs (see below).
Rebooted both cRIOs.
Now have access!
The hosts files:
169.254.0.3:
127.0.0.1       localhost.localdomain           localhost
169.254.0.3     NI-cRIO-9066-01cc788a.local     NI-cRIO-9066-01cc788a
169.254.0.2:
169.254.0.3     NI-cRIO-9147-01cb9b6c.local     NI-cRIO-9147-01cb9b6c
Thank you NI support for helping out with this one.
Peter.
(3,133 Views)
