NI 9871 module detailed hardware specifications
   hi,
i want to learn the details on NI9871 module box specifications.. i search but manuals just give me pin connections, bus topology, etc ..
how can i learn the positions of RJ50 x 4 sockets window, power connector window and 15-pin DSUB window, on the module box.
  best regards..
(2,645 Views)
Accepted by topic author davut
Hi davut,
what "windows" are you talking about?
Do you need CAD drawings to specify actual positions of the connector plugs?
Well, the front side is ~10cm high and holds those 4 RJ45 plugs as well as the power plug. You need wires anyway to electrically connect to the module, so it shouldn't be a problem if the plug is some millimeters away from an ideal position...
If you really care about that: call NI and ask for a CAD schematic. Or ask for a module for testing purposes, most often they have some in store...
(2,640 Views)
