PISTON /Hydraulic Control GUI or UI
I want to make a GUI which is well animated showing the fluid flow.
I am using six Hydraulic Cylinder which are piston type.
I want make a Piston type action with the labview.
I have DSC module and checked the image navigation. I could'nt find the some good clipart.
I found a picture on net which can be used but I am not sure how can show the flow of liquid within the picture.
The Hydraulic Cylinder expant and retract, position sensors are also attached.
How can I make my UI more realistic or animated?
How to make animation in the GUI? There are no images which are animated in the DSC module also.
Please advice!
(3,264 Views)
Hello KRAZE4LV,
If you want to use an animated GIF, there are a couple of resources out there about how to set it up.
Here is a knowledgebase article:
http://digital.ni.com/public.nsf/allkb/726108fbedfe5f9d862571de00505051?OpenDocument
This is an article about someone who set up an animated GIF as a control:
https://decibel.ni.com/content/docs/DOC-7482
This article shows examples of different animated buttons and indicators:
https://decibel.ni.com/content/docs/DOC-4035
You can also create custom controls, and have the two (or more) states of the control correspond to different images. Then within your code just have a loop that access the control through property nodes and modifies the state of the control in order to switch between the two images - thus creating an animation.
If you want a higher resolution animation, you can use a picture ring control. See:
https://decibel.ni.com/content/docs/DOC-2270
Colden
(3,236 Views)
