Autoscale
I am creating a VI for acquiring ECG signals. I have attached a screenshot of my VI. I have following doubts.
I would appreciate if you could help me in solving them.
1. I want manual autoscaling of the Y axis i.e. Amplitude. That is it will autoscale only when you click a button on the front panel. Can you please tell me how to do it?
2. I want  "window duration" parameter on the front panel for adujusting the widow duration of X axis. How to do that?
Thank you.
(3,518 Views)
Accepted by topic author abcdd
(There is no screenshot in your post.)
To autoscale once, you would use the "Scale fit" proerty wired with a 1 (0:do not autoscale, 1:Autoscale once now, 2:autoscale)
Put the property node inside a case structure connected to a latched boolean button.
To adjust the range of the x-axis, you can set the range also with a property node.
(3,509 Views)
Thanks for your reply. Here is the screenshot of my VI. I need to attach the property node inside the case structure right?
Thanks in advance.
(3,475 Views)
(Screenshots are nearly useless and you don't have a case structure yet. It is always better to attach an actual VI.)
Yes, place a case structure inside the WHILE loop, place the property node inside the true case, and trigger it with a latch action button as needed.
(3,468 Views)
