‎04-20-2021 11:50 PM
Hello seeking advice here! I’ve been thinking about moonlighting by pursuing work with NI Alliance Partners. I have my CLD, and otherwise have become well rounded in design, documentation, controls, Java, IT, and that general space working on an agile test tools team. Is it easy or difficult to get part time work in that space? What kind of hours should I expect if I did this full time? Should I expect 3 a.m. types of calls? What kind of compensation can one expect initially, after 3 years, and after 5-10 years? Just looking for any high level overview of that work environment. Thanks for your time and knowledge.
‎04-21-2021 04:55 AM - edited ‎04-21-2021 04:57 AM
It will mostly depend on your marketing and communication skills. Just knowing the technical aspects, no matter to what depth, will not give you an income that can sustain you, except maybe if you manage to capture a very small niche where you are the world leading specialist. But in our fast paced technology even such a niche is likely to be a short term solution, lasting only a few years at best.
It's definitely not easy to do, with many pitfalls and potential problems. A passion for what you plan to do certainly helps, but you really need to think about how you are going to sell your services. That's where everything starts and also ends. Without some kind of well planned marketing approach, you will continually struggle to make ends meet.
Of course, marketing alone will also not really work. You also need to have something that you can sell, unless you want to end up selling snake oil. 😀
