NI Auth Adobe Flex HTTPService
I want to ask how to call Labview web server (secured using NI Auth) from Adobe Flex application.
(2,993 Views)
Please find the documentation and example at:
http://zone.ni.com/devzone/cda/tut/p/id/7350
Mircea
(2,977 Views)
Thank you for the reply. The communication between LV and Flex works fine without NI Auth (this situation is described in the example) - My question is how to set the HTTPService in flex to work with NI Auth - how to send username and password from Flex to Silverlight login screen. I need to write something like the VI "OpenHandle" in Flex, but because this VI is secured with password I cannot see what is it doing (??probably modifying the header ???).
BR
Pavel
(2,973 Views)
Dear Pavel,
Thank you for your reply. What I have found so far is the following document, which describes how NI Auth can be configured and can be programatically called from LabVIEW,
http://digital.ni.com/public.nsf/allkb/DF41D5DA8EEB4840862577D90058C208?OpenDocument  - surely you browsed through this document, but just in case.
This approach could help you:
http://stackoverflow.com/questions/490806/http-basic-authentication-with-httpservice-objects-in-adob...
Let us know how it worked out for you,
Mircea
P.S. Did you consider looking at NI Web User Interface Builder?  http://www.ni.com/uibuilder/  - let me know what you think about it
(2,963 Views)
For in-depth questions and recommendations, I would strongly recommend:
NI Talk, LV Web Services Group
http://nitalk.natinst.com/groups/lv-web-services?view=discussions
Mircea
(2,961 Views)
