NI Auth image
Is it possible to change or remove the standard image that NI auth produces above the login?
I am using NI auth to secure a web service deployed on a sbRIO, and it would appear better if the image were gone. Is there a copy of the image stored on the sbRIO somewhere? Or is it 'compiled' into the Silverlight plug in?
(3,507 Views)
Accepted by topic author SuperDuperCooper
My name is Mitchell from National Instruments Technical Support.
As far as as I'm aware of, there doesn't seem to be away to really change or remove the NI logo from the login.
Kind Regards,
Mitchell
(3,441 Views)
Hi Mitchell
Thanks for the response.
Perhaps it would maybe be a nice and fairly simple(?) upgrade for the next version of LabVIEW.
Cheers
(3,381 Views)
