NI-CAN support for LabVIEW 2011 64 bit
I am trying to update the drivers for a NI-CAN for 64 bit LabVIEW 2011. It seems that this is not available, how can I go around this issue. Do I have to use the 32 bit version?
(2,800 Views)
You will need to use the 32 bit version of LabVIEW to use NI CAN. There is no CAN driver yet to interface with the 64 bit version of LabVIEW.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,796 Views)
Is there any other way I can read from a the can bus in labview 2011 (64 bit)? I have a NI USB-8473.
(2,792 Views)
I wouldn't think so. You will need the 32-bit version.
Adnan Zafar
(2,790 Views)
As Adrian mentioned, unfortunately, there is no NI-CAN 64-bit driver.  As this KnowledgeBase article mentions, you can use the 32-bit driver (with 32-bit LabVIEW) on your 64-bit OS, but not with LabVIEW 64-bit.
Austin S.
Academic Field Engineer
(2,770 Views)
