NI-CAN
I am getting the following error when trying to initialize CAN communication: Error -2147024891 occurred at Access is denied.
Anyone knows what this means? I know the Copley motor works, I can access it via serial communications. The CAN card seems OK also, I did a self test via NI-MAX.
I have the following configuration:
LabVIEW 8.6
1 port, high speed series 2 CAN interface, PCMCIA
NI-CAN drivers 2.7.2
Copley Micro Accelnet Micro Panel servo
KBT
(2,470 Views)
is MAX closed when you try to launch commuication with your CAN card ?
V-F
(2,459 Views)
