 Kapil05
			Kapil05
			10-26-2018 05:35 AM
Hello all,
It may not be a right group for seeking support. Here ar emy quesries..
I am using LabVIEW 2018 for my project and I will require NI DAQ assistant for my program. I have installed the NI DAQ MX driver but still I the related VIs are not visible in LabVIEW. Please suggest the solution for this.
Thanks and Regard.
 crossrulz
			crossrulz
			10-26-2018 06:34 AM
What version of DAQmx did you install? Did you reboot your machine?
10-26-2018 07:16 AM - edited 10-26-2018 07:17 AM
Hii,
I have installed 18.0 of it. Yes I have repeated the whole sequence several times.
 RavensFan
			RavensFan
			10-26-2018 08:28 AM - edited 10-26-2018 08:29 AM
What version of LabVIEW and DAQmx did you install, as in the "bitness"? Could one have been the 64-bit version and the other the 32-bit version?
Show your software branch of the tree that you have when you open up NI MAX.
