NI DAQ Mx driver has been intsalled but not available in LabVIEW 2018 functional palate
Hello all,
It may not be a right group for seeking support. Here ar emy quesries..
I am using LabVIEW 2018 for my project and I will require NI DAQ assistant for my program. I have installed the NI DAQ MX driver but still I the related VIs are not visible in LabVIEW. Please suggest the solution for this.
Thanks and Regard.
(2,637 Views)
What version of DAQmx did you install?  Did you reboot your machine?
(2,626 Views)
Hii,
I have installed 18.0 of it. Yes I have repeated the whole sequence several times.
(2,615 Views)
What version of LabVIEW and DAQmx did you install, as in the "bitness"?  Could one have been the 64-bit version and the other the 32-bit version?
Show your software branch of the tree that you have when you open up NI MAX.
(2,606 Views)
