NI DAQ USB 6008 is not detected
Hi Duncan,
Thank you for the suggestion. I tried that now, but the problem is still the same as before unfortunately.
//Pamela
Message 11 of 13
(1,659 Views)
Accepted by 50616d656c61
Hmm this is a strange problem. I was able to find another instance of this issue occurring in this archived KB. It seems you can assign a driver to your device manually and may need to if Windows does not recognize the DAQmx drivers as being signed drivers. Based on what you have described, I feel pretty confident that this issue is between the OS and the drivers so I would recommend looking through all of the available documentation on Windows/DAQmx compatibility issues.
Duncan W.
Message 12 of 13
(1,655 Views)
Hi Duncan,
Thank you SO much. I assigned the driver manually to the device and now it works.
Thank you, both of you, for spending time helping me.
//Pamela
Message 13 of 13
(1,652 Views)
