NI DAQ capable of +/-15V Output
Hi guys, is there any available DAQ or NI USB that's capable of outputting at least +/-15V and also can accept input as high as +/-15V? all I can search is up to +/-10V only
(4,675 Views)
Hi dragonknight,
±10V is the usual range for devices capable of both input and output of analog signals.
What about using some external signal amplifiers?
(4,655 Views)
Accepted by dragonknight255
There's quite a jump, but you can e.g. use http://ohm.ni.com/advisors/compactdaq/pages/common/helppopup.xhtml?conversationContext=1&url=http://sine.ni.com/nips/cds/view/modelpopup/p/pcat/18513  that can measure 250V (it's the 1st i found)
NI 9269 can output +/- 40V https://www.ni.com/en-us/shop/category/voltage.html?productId=118154
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,643 Views)
NI 9221/9228/9229 are capable for +/- 60 V analog input, see here: https://www.ni.com/en-us/shop/category/voltage.html?productId=118152 (you can filter them by "Analog Input Voltage Range".
(4,634 Views)
