NI DAQ capable of +/-15V Output
Hi guys, is there any available DAQ or NI USB that's capable of outputting at least +/-15V and also can accept input as high as +/-15V? all I can search is up to +/-10V only
(4,655 Views)
Hi dragonknight,
±10V is the usual range for devices capable of both input and output of analog signals.
What about using some external signal amplifiers?
(4,635 Views)
Accepted by topic author dragonknight255
There's quite a jump, but you can e.g. use http://ohm.ni.com/advisors/compactdaq/pages/common/helppopup.xhtml?conversationContext=1&url=http://sine.ni.com/nips/cds/view/modelpopup/p/pcat/18513  that can measure 250V (it's the 1st i found)
NI 9269 can output +/- 40V https://www.ni.com/en-us/shop/category/voltage.html?productId=118154
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,623 Views)
NI 9221/9228/9229 are capable for +/- 60 V analog input, see here: https://www.ni.com/en-us/shop/category/voltage.html?productId=118152 (you can filter them by "Analog Input Voltage Range".
(4,614 Views)
