 VoN.94
			VoN.94
			10-11-2017 09:24 AM
When I try to install DAQMX,the installation crashes and shows me the error in the pic.How can i resolve this issue??
 rake615
			rake615
			10-11-2017 10:27 AM
Is this a fresh install? If you already had older drivers installed it can corrupt you install files. I usually remove the older version before installing 17.0 specially if they are version 9 or older.
10-11-2017 11:16 AM
I don't have any older version of Labview
and yes it is a fresh install
what are my other option to make the daqmx installation work?
 rake615
			rake615
			10-11-2017 11:34 AM
The drivers requier .NET framework. Repair the .NET in windows or try uninstall and reinstall, then try installing drivers again(remove whatever is left of the DAQmx driver before reinstall).
