NI-DAQmx 7.5 upgrade failure causes MAX seizure?
I have just attempted to upgrade my NI-DAQmx from 7.3 to 7.5 by downloading and running the driver per the install.txt.  After an apparently successful install, MAX locks up as it is trying to start.  All I get is the splash screen.  Any suggestions?
(3,048 Views)
My first thought would be to reinstall. Something probably didn't go right during the install.
I just upgraded from 7.4 to 7.5 and so far everything's OK.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,047 Views)
Ok, it looks like I needed to also update my legacy NI-DAQ.  Once I did that, MAX started up ok.  My next hurdle is finding out that the ONLY NI-DAQmx device that I can't seem to simulate is the SCXI-1600, which is precisely the one I want!  I'm doing some development of interfaces, etc., off-line, and the system in question uses the 1600.  Can I select a DAQ device that I can "connect" a simulated SCXI chassis that will come close to the behavior of the 1600?  Can someone recommend a particular one that should require minimal changes moving to the real deal?  I set up a 6031E and SCXI1001 just to show myself that could work, but didn't know how peculiar the 1600 really is.
(3,036 Views)
You can actually simulate 1600.
When you select to Simulate a device, expand the SCXI Chassis section and select the chassis you will be using. In the next dialog, you'll notice that it uses a 1600 by default for communications.
Ed
(3,025 Views)
