NI-DAQmx 8.5 download file bad?
I have tried downloading it twice, and when I try executing it I get a window that says "NIDAQ850.exe is not a valid Win32 application."  Is there a way I can run a checksum on the file to see if it is corrupted?  Can someone tell me what the checksum should be?
Brad
(2,738 Views)
Hi Brad,
I have download the file and runs fine on XP machine. I have attached a program to read the checksum of files. On my end it was "1981745157" (decimal) and the file size is "849488672" bytes. Other problems might include some restriction with your IT department and EXE files.
Hope this helps,
Gerardo O.
RF SW Engineering R&D
(2,720 Views)
