no negative gridlines on waveform plot
I have what is essentially an oscilloscope plot.  I the Y-Scale parameters based on user input for Full Scale and Offset.  The limits are OS +/- FS/2.  The major ticks are 0.1 FS, and the minor ticks are a further 1/5.
I get the curious phenomenon that tick marks, their values and gridlines for negative values do not get displayed (except the minimum limit which does).  I'm setting these values using a reference to the plot and a WFGraph (strict) -> YScale.Range property node.
Am I doing something wrong?  Is this a bug?  Any suggestions?
Tom J
(3,256 Views)
Please post a simple example that demonstrates for us to look at.
We do much better with examples.
Ben
(3,248 Views)
In the process of stripping the program down, I figured out my problem.
I needed to wire the value for YScale.Range.Minimum into YScale.Range.Start as well.
Thanks for responding.
Tom J
(3,237 Views)
