NI DAQmx Base Driver
I’m looking for some advice on how to create a driver for my HP PDA model hx2190b using NI DAQmx Base 2.0.  The device I’m trying to talk to is a Texas Instruments TRF7960 RFID evaluation board.  It has a USB interface.  I’m using a CFU2 USB host flash card from Ratoc Systems in my PDA.  Any examples or can you point me in the right direction to find out how to accomplish this?  I already ask TI for a driver and they said they don’t have one for the PDA running Windows Mobile 5.0.
Thank you,
Steve…..
(6,059 Views)
Hi Steve,
The NI-DAQmx Base driver can only be used with NI data acquisition products and cannot be tailored for use with 3rd party devices.  I think what may work best for you are the USB communication VIs that are included with the NI-VISA driver.  You could use these with the LabVIEW PDA Module, and you may even be able to use the VISA Driver Development Wizard to create a custom driver for your USB device as long as the evaluation board conforms to the USBTMC specification.  Check out the Developer Zone article here for more information.
NI-VISA Download
Andrew W
(6,030 Views)
