NI-DAQmx Driver support for Labview 2017 is missing
I have LabVIEW 2017 installed and I want to use the NI USB-6001 device for data acquisition. However, I'm unable to find the NI-DAQmx VIs under the Measurement I/O palette in LabVIEW.
I have already tried installing various versions of the NI-DAQmx driver using NI MAX, including versions 20.7 (which is the latest version supported by LabVIEW 2017), 19.6, and 19.5, but the issue persists.
Additionally, I would like to use the NI USB-6001 with MATLAB. For this, I have installed the Data Acquisition Toolbox from the Add-Ons menu in MATLAB.
Please help me troubleshoot this issue.
(1,075 Views)
Accepted by Pra5een
When you installed LabVIEW 2017, you should have also installed NI DAQmx, which certainly can work with a USB-6001.
Do you have access to another PC with LabVIEW 2017 and DAQmx installed?  See if your USB-6001 will appear when you plug it in and open MAX (it should show up in Devices and Interfaces).
Do you have access to a PC with no version of LabVIEW installed?  Try installing a "clean" version of (only) LabVIEW 2017, along with the DAQmx drivers.
It would help us to help you if you open MAX, expand "Devices and Interfaces", and send us a screen-shot (maybe with the Software tab expanded) so we can see what might be missing.
(993 Views)
Got it working after repairing LV 2017
(983 Views)
