10-01-2018
06:45 PM
- last edited on
03-12-2025
03:28 PM
by
Content Cleaner
I have just installed Labview 2018 on a Mac and am now attempting to get all the drivers correctly installed. For Labview 2017, this page:
https://www.ni.com/en/support/downloads/drivers/download.ni-daqmx-base.html#326059
has packages to update the latest NI-DAQmx driver (which looks to be 2015) to Labview 2016 and 2017, but not 2018. Is there a corresponding update package for LV2018?
10-02-2018 09:55 AM
Which drivers exactly do you need to install besides NI-DAQmx driver?
Pamela Gómez
Applications Engineering
www.ni.com/support
10-02-2018 10:35 AM
Hi Pam,
I think I misspoke slightly. What I am actually trying to do at present is communicate with a USB-6008 usinv LV2018 on a Mac. I successfully installed the NI-DAQmx base package (v15.0), and the standalone NI-DAQmx programs that were installed with that package can communicate with the 6008. Now what I need is the DAQ tools/VIs for Labview 2018 -- the Measurement I/O tools panel is empty and the example VIs don't appear to be present. I assume this is what the add-on packages for LV2016 and 2017 fix, but of course they won't install for LV2018 without modification. So the question is how to fix that.
thanks,
10-03-2018
08:07 AM
- last edited on
03-12-2025
03:31 PM
by
Content Cleaner
Please check this white paper, it should be useful.
http://zone.ni.com/reference/en-XX/help/371361R-01/lvhelp/troubleshooting_guide/#missingDriversMac
Pamela Gómez
08:20 AM
- last edited on
05-23-2025
06:08 PM
by
Content Cleaner
There is still a problem with that. It doesn't seem to lead to DAQmx Base 18.0, only 15.0
LabVIEW may not be able to locate certain subVIs, palettes, or Property Nodes for the following reasons:
That link I made larger takes you to: http://sine.ni.com/nips/cds/view/p/lang/en/nid/14480
That page has Download NI-DAQmx Base
The title of that page is NI-DAQmx Base 15.0 - Windows 8 32-bit/8 64-bit/7 32-bit/7 64-bit/Vista 32-bit/Vista 64-bit/XP 32-bit
That has a ReadMe readme.htm which has this link Support in NI-DAQmx Base 15.0.0
Go there and you have
The following table lists the application software versions supported by NI-DAQmx Base 15.0.0:
| NI Application Software | Versions Supported by NI-DAQmx Base 15.0.0 |
| LabVIEW | 2012, 2012 SP1, 2013, 2013 SP1, 2014, 2014 SP1, 2015 |
No LabVIEW 18.
10-03-2018
03:07 PM
- last edited on
03-12-2025
03:32 PM
by
Content Cleaner
OK, I have solved this, sort of. This page:
http://www.ni.com/download/ni-daqmx-base-15.0/5648/en/
under 'supporting files' has this link:
NI-DAQmx Base Addon for LabVIEW 2017
I downloaded that, which is a zip-file that unzips into a directory. The directory has an install shell script that you are supposed to run. All it does is place the other files in the directory into the appropriate places in /Applications/National Instruments/Labview 20XX. I edited the install script to replace "2017" with "2018" and ran it. This placed all the included files into /Applications/National Instruments/Labview 2018 64-bit/.
Then I started Labview 2018 and found that the correct tools were in the measurement I/O palette and the DAQmx example VIs are in the examples folder where they are supposed to be. I was able to communicate with the USB-6008 using the appropriate example VI.
So basically what I did was shove the 2017 extension files into Labview 2018. So who knows if they all work with 2018, but this appears to work for my application.
Basically it appears that someone at NI just has to check that everything in the 2017 package works with 2018 and change the install script.
10-08-2018 07:29 PM
I performed a fresh installation of LabVIEW 2018 and NI-DAQ Base 15.0 plus the NI-DAQmx Base for LabVIEW 2017 additions, using the shell script in Terminal with the script modified to replace 2017 with 2018. I also installed NI-VISA_18.0.0, and for good measure NI-488.2 18.0 even though I'm not using GPIB. My hardware is a USB-6218. It works, sometimes. When it doesn't work, sometimes restarting LabVIEW fixes it. Sometimes just running NIvisaic/app or lsdaq.app, or unplugging and replugging the hardware wakes it up. But not reliably. Otherwise I have to reboot the Mac. It's very flaky.
One anomaly I noticed is when I run the NI-VISA Server it tells me I'm missing at least one passport and that I should run the NI-VISA Server configuration utility. But when I do that it looks like all the passports are checked and doesn't indicate that anything is missing.
I would love for NI to tell me exactly what I need to do to get this to work. It should be simple, and understandable. If it isn't they should put resources on it to make it so. Do they really expect me to understand the correct settings of my "Bulk out Pipe" and my "Bulk in Pipe"??
