03-29-2019 06:58 PM
Hello friends, I am a engineering student and I am currently starting to work with LabVIEW NXG 3.0, but I do not know where to download the NI-DAQmx libraries for this version of LabVIEW and I do not know how to install them either.
I need help plase.
Greetings and thanks. 🙂
04-01-2019 09:26 AM
I am not sure what the best way is, but how did you get LV NXG? Usually it has an installer, and there you can select the DAQmx driver. You can rerun the same installer and select NXG and DAQmx and it will only install what you don't already have on you computer. I don't know if that will work for you.
04-01-2019 01:51 PM
Hello dPeregrina! The NI-DAQmx version you need is the 18.6. This version works with LabVIEW NXG 3.0. Try it, it should work! If it does not, please don't hesitate in replying me! 🙂
This is the link to the download:
http://www.ni.com/es-mx/support/downloads/drivers/download.ni-daqmx.html#291872
Regards!
