NI-DCPower Output Function Error in example libraries
Dear all, thank you in advance for any help from you.
This question because I received an error message in running a .vi from the LabView example libraries. The example is the "NI-DCPower Pulse Voltage.vi", I am using a SMU NI PXIe-4145. The received error message is the following: "Error  -1074135024 occurred at niDCPower Configure Output Function.vi - Invalid value for parameter or property".
It is strange to receive an error from an example. Other examples can work fine with the same SMU. I attached the images for clarity, I have not modified anything....
Thank you for all you can suggest to me.
Best. G.
(3,410 Views)
Accepted by GT_
(3,367 Views)
You are right....thank you.
G.
(3,346 Views)
