NI DMM Problem
Dear all,
I have NI PXI-1033 device and together with it a digital multimeter PXI-4065.
I followed the instructions and installed the device. Everything was working perfectly till the moment I install the vision development module, then after the restart the multimeter was not anymore found by the MAX.
Can anyone please help me to solve this issue.
Cheers,
IG.
(4,156 Views)
Hi IG
Is the DMM your only card in the Chassis? If no, can you see the other cards?
Best Regards
David
NISW
(4,140 Views)
No, I have PXI-6514 as well, but I have the same problem with it. Any suggestions ?
Best,
IG.
(4,138 Views)
Can you still see the MXI card in your computer? Have you tried unplugging the cable, rebooting both computer and chassis and then replugging the cable?
Best Regards
David
(4,133 Views)
Accepted by igurov
What version of MAX are you using? Try upgrading or repairing it.
/David
(4,132 Views)
Repairing did the job! Thx
(4,128 Views)
You're welcome, happy to help
/David
(4,126 Views)
