NI Device Monitor pop up- disable?
I have a test program & fixture that will be deployed to the factory that uses two NI-6501 DAQs. When the fixture is plugged into the host pc, the NI Device Monitor pops up indicating it found an NI device. Normally that's good, but when the factory operator plugs in the test fixture with the DAQs, I don't want them to have to deal with the "USB-6501 Detected" popup and wonder what to do about it. Is there any way to disable that popup w/o disabling the Device Monitor?
(3,023 Views)
Accepted by hammer3
right click on it in the system tray, deselect run at startup. You can always run it manually later if you need to
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,021 Views)
