NI Error Reporting Interface 15.0 error when creating a LabVIEW 2014 installer package.
For what it's worth, I found an official NI solution for the problem, and it's remarkably simple.
Find it here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kG0dSAE
tl;dr use NI updater to get the latest version of LabVIEW and the RunTime Engine.
One would think the as-installed product right off the CD would work...
Message 21 of 24
(2,686 Views)
Hi Bauer_CT,
Yes, I know about the NI Updater. But it forces you to buy the latest version.
If you are not able to do so, the previous solution(s) are the best way to go.
Message 22 of 24
(2,677 Views)
That is not true. I do not have SSP any more, so the latest available to me is 2016. The Updater just got me updates for the 2015 versions.
Message 23 of 24
(2,668 Views)
Re-installing Labview Runtime 2014 (LVRTE2014SP1_f11Patchstd) did the trick for me.
Message 24 of 24
(2,466 Views)
