NI LabVIEW RIO Evaluation Kit
I bought the NI LabVIEW RIO Evaluation Kit and i need the datasheet as soon as possible, please help. Thanks Smiley Happy
Message 1 of 16
(6,803 Views)
This is a user supported forum, what you are asking for would best be handled through the formal National Instruments channels. If you can, contact your local National Instruments office for help. What are you looking for exactly, can it not be downloaded from the NI site? Usually all of that type of info is available online.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 16
(6,797 Views)
I think the links from the eval kit under the resources tab are broken as the one for the manual takes you to a Test Stand manual, see http://sine.ni.com/nips/cds/view/p/lang/en/nid/205721  - Mike
Message 3 of 16
(6,782 Views)
I have put in a request to get the link fixed. I found this link that may be useful https://www.ni.com/en/support/documentation/supplemental/21/ni-labview-rio-evaluation-kit-faq.html. What info did you need from the manual? I'll see if I can get my hands on that specific info as well as the manual from our end.
Ben D.
Message 4 of 16
(6,771 Views)
I've also been trying to locate the manual. I need to know the sampling rate of the A/D converter on the board.
Farhan
Message 5 of 16
(6,760 Views)
Here is the manual for the sbRIO board specifically included with the evaluation kit. https://www.ni.com/docs/en-US/bundle/sbrio-9605-9606-9623-9626-9633-9636-seri/resource/373378d.pdf
If you have any more specific questions, please don't hesitate to ask here.
Ben D.
Message 6 of 16
(6,737 Views)
Which sbRIO Board is deliverd within the evaluation Kit?
Im planning to use them and I need to check son deatils in bevore.
Yours sincerely
Florian
Message 7 of 16
(6,394 Views)
The sbRIO-9636 is the board included with the evaluation kit. Hope this helps!
dK
Message 8 of 16
(6,362 Views)
This helps a lot.
This Board includes all features the sbRIO-Platform provides.
Is it possible to access and test these features (e.g. COM Ports and CAN) when I purchase the Kit?
Tanks
Florian
Message 9 of 16
(6,348 Views)
Yes, the RIO Evaluation Kit is just the sbRIO-9636 board with a LabVIEW RIO Evaluation board connected to it. The LabVIEW RIO Evaluation board has a digital encoder, LCD screen, function generation, etc. If you want, you can disconnect the evaluation board from the sbRIO-9636 and work straight with the 9636. Hope this answers your question!
dK
Message 10 of 16
(6,328 Views)
