NI LabVIEW RIO Evaluation Kit
Thank you verry much.
Message 11 of 16
(1,357 Views)
Hi, I'm running the device right now and following the 5 exercices given in tutorial. But on the 3rd exercice, on the 8th step, one file is missing it's called according to the manual : RT or UI button press(SubVI).vi
It should be on the .\3- Create Real-Time Application\VIs folder but it is not.
So can someone send it to me so I can move on with it please?
Thank you very much.
Message 12 of 16
(1,345 Views)
After 90 days of evaluation period should I need to return hardware to national instruments ,I just thought only software will be expired after 90 days
Message 13 of 16
(1,019 Views)
AFAIK the hardware is yours to keep. If unsure, aks your NI representative about it.
Regards, Jens
Kudos are welcome...
Message 14 of 16
(1,012 Views)
Hello Mr Jens,
Thank you for your reply regarding the issue, could you tell me that evaluation hardware kit works if i have full licenced labview suit. Once again thanks for your kind support.
With regards,
M Sai Kumar
Message 15 of 16
(1,002 Views)
Dear sai_kumar,
If the following link does not answer your question (in particular section 4), you can ask your NI representative, or email support@ni.com concerning your question if you wish. Also, it is generally a good idea to either create your own forum post for your question or if you are going to ask a question on a forum that you did not start, to make sure that it is a current thread. When you first posted, this thread had ended 4 years ago, so you were lucky that anyone saw your post.
NI LabVIEW RIO Evaluation Kit FAQ
Alyssa H.
Message 16 of 16
(990 Views)
