NI MAX Empty UI
I am upgrading DAQmx and other software associated with LabVIEW 2009 to the latest supported version to allow use with a cDAQ 9174. After installing DAQmx 9.7, when I open NI MAX, I see the user interface, but none of the options in the sidebar are available. I have tried the troubleshooting options suggested in this thread, but I have not had any success in getting the items to appear. What other steps can I take to make NI MAX functional?
(3,145 Views)
Accepted by DBBoman
-Try Resetting the MAX Database using the steps in :https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
-If above step fails Try uninstalling and/or repair using steps in this: https://www.ni.com/en/support/documentation/supplemental/18/uninstall-or-repair-national-instruments...
-What is the MAX version installed?
uday
(3,096 Views)
