NI MAX Failing To Login To Remote Device
I'm working on setting up a new cRIO 9034 but I am unable to perform initial software configuration due to NI MAX failing to login to the cRIO. I know I'm using a valid user name and password because I am able to login to the cRIO via its webpage.
Anyone know why NI MAX would have this issue?
(632 Views)
Accepted by topic author ml_12345
Hello Michael,
A Thread has been posted before with a similar issue, check it out here.
You could try the solutions in the following link I believe they are related to your issue: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019WJbSAM&l=en-GB.
You can also try downloading the cRIO drivers from ni.com if you haven't already: https://www.ni.com/en/support/downloads/drivers/download.ni-compactrio.html#564323
Let me know if this doesn't work :).
Dom
(578 Views)
Yes, thank you. The thread you linked had the correct solution. The only variation was the NO_PROXY variable was a user variable instead of a system variable.
(533 Views)
