10-27-2023 12:09 PM
Hi dear all,
i have installed LabView nxg4 and along that MAX 20.0 on my pc Win7.
The problem that i am facing is that my MAX tree "Remote System" Tab cannot find any remote systems.
I am using usrp-2944
10-27-2023 03:14 PM
Unfortunately, you are using no-longer-supported software (NXG4) on a no-longer-supported Operating System (Windows 7). I recommend that you update to Windows 10 and a supported version of LabVIEW.
10-27-2023 04:50 PM
Will it work if i upgrade to win10 and nxg5?
10-28-2023 04:14 AM
NXG was discontinued around 2019/2020 and is nowadays more dead than a dead fish in water. That said, before any software (including NI-MAX) in your computer can see your USRP device, you will need to install NI-USRP software drivers. But Windows 7 is definitely trying the software Gods nowadays for any software released in 2020 or later. And you likely don’t want to install NI-USRP 2015 or similar but something a bit more recent.
10-29-2023 08:23 AM
ok
I am trying to transfer files between two PCs using FileZilla, but this problem has stopped me. Is there another way to transfer files using FileZilla or through alternative methods.
10-29-2023 10:18 AM
The "safest" way to transfer files between two PCs is by doing a copy of the files to an "intermediate device" (which can mean copying them to a USB Flash Drive, burning them on a CD/DVD, copying them to a "network share", copying them "to the cloud", or committing them to a Version Control System, the recommended method for "software Source files"). Once you have a copy on another medium, you connect the other PC to this medium and "copy the copy" to the second machine. Have you never done this before? A "hidden virtue" of this method is if you somehow "mess up the copy on both PC1 and PC2", you have a "copy of the original" that should be intact.
