NI MAX could not launch
Well, Finally i managed to use the MAX Corruption Removal tools , to delete the directory, tou must first stop the services :
Follow this procedure :
  • Select Programs » Accessories from the Windows Start menu.
  • Right click Command Prompt and select Run as administrator. If the command prompt is run without administrator privileges, you will receive System error 5 has occurred. Access is denied.
  • Type net stop mxssvr and press Enter to stop the MAX database service. If you are prompted to stop other services, stop them.
  • Type exit and press Enter to close the command prompt window.
Unfortunately even if the tool say the database is corrected, MAX still doesn't start !!
Message 11 of 48
(15,013 Views)
Shooot...!
Now you would kill me for this but have you tried uninstalling the rest of the stuff (NI Product) and reinstalling it again with ADMIN previllages after ' MAX Corruption Removal tools' procedure ?
I haven't find any alternative solution for this thats why trial and error basis is the only chance to get the solution else you can contact nearest NI support!
Message 12 of 48
(15,009 Views)
Not for the moment, the problem is this will take one day to reinstall all NI stuff, and in a post before, gustavosimao wrote he already tried to reintsall labview without success ...
So.. should i loose one day without guarantee... that's the question ....
Message 13 of 48
(15,006 Views)
kabooom escreveu:
kaboom, do you have any better idea than reinstall OS?
Message 14 of 48
(14,994 Views)
No better idea... but it's just not possible !!
I will open a support with NI, and i really hope they have a solution...
Message 15 of 48
(14,985 Views)
Accepted by gustavosimao
The problem seemed to be caused by an old version of the "nisysapi.dll" that is a depends of the "mxrmcfg.dll" and lays in Windows\SysWOW64 on a 64bit machine. We have renamed it, replaced by the version 15.xxx copied from another machine, rebooted and purged %TMP% and trashcan. MAX can be started again.
Message 16 of 48
(14,979 Views)
thumble escreveu:
It worked!! Thank you!!
Message 17 of 48
(14,963 Views)
same problem with me ... how to fix it?
Message 18 of 48
(14,598 Views)
As said by Thumble:
"The problem seemed to be caused by an old version of the "nisysapi.dll" that is a depends of the "mxrmcfg.dll" and lays in Windows\SysWOW64 on a 64bit machine. We have renamed it, replaced by the version 15.xxx copied from another machine, rebooted and purged %TMP% and trashcan. MAX can be started again."
This solved my problem.
Message 19 of 48
(14,587 Views)
Thank you. It's working
gustavosimao 已寫:
As said by Thumble:
Thanks. It's working
Message 20 of 48
(14,583 Views)
