NI MAX could not launch
Hi all,
I tried to launch NI MAX in win. 10 with the intention of detect a Keithley 2100 multimeter connected by USB. Since it is not Plug and Play device I click in "Create New...", but is prompted the screen that you can see in the pic attached. the device is detected by the Device manager (under the name "2100 Multimeter") but not by NI MAX (even if I click on Refresh button).
Please, does anyone any hint about this issue?
Thank you very much in advance.
(3,554 Views)
@EstebanP wrote:
Hi all,
Go to NI MAX >> Tools >> Reset configuration data and restart your PC.
(3,511 Views)
If you search the Web for "Keithley 2100 LabVIEW", you will find a number of "hits" about accessing this device from LabVIEW.  Sounds like a solution does exist ...
(3,505 Views)
@SabariSaravanan.M wrote:
@EstebanP wrote:
Hi all,
What the.....?
Dude, that is the last thing you want to do.  The Instrument will show up as a VCP when connected via USB. The device type cannot be automatically detected from MAX or anywhere else unless you chat with it via VISA.
And whoever gave you a CLD?
(3,498 Views)
Accepted by EstebanP
Hey EstebanP,
Could you check you have NI-VISA installed (NI-VISA 18.0), and that you have the latest version of the firmware on the device. Looks like this is V1.09.
Also check NIVIUSB.dll is checked in MAX (select Tools » NI-VISA » VISA Options... Once the VISA Options screen appears, select Passports in the tree view (My System » General Settings » Passports).
If so, then the next step would be to force reinstall NI-VISA to ensure there is no corruption. Check out  A Code Library Required by NI-VISA Could Not Be Located. Although it's different systems the steps go through ensuring NI-VISA is correctly detecting the device.
Hope this helps. Let us know how it goes.
Rebecca
(3,463 Views)
Hi Rebecca,
thanks a lot. Installing NI-VISA 18.0 solved the problem (they recommed higher that 13 and I had 15 installed), despite the firmware version is 01.07-01-01 (probably not the latest).
Anyway, thank you so much.
cheers
(3,458 Views)
