NI MAX does not recognize an instrument connected via USB
Hi!
I'm trying to develop drivers in LabVIEW for an USB instrument. My problem is that on NI max, I do not see the instrument. In Windows devices (windows 7 - 64 bit), it is recognized as: USBIO controlled devices - USBIO Device: VID = 03EB PID = 2FFB, and with its software installed on the PC works correctly. How can I solve?
Thank you
(9,207 Views)
Accepted by sepp974
These are some results after searching for "ni max usb devices" using Google.  They should point you in the right direction.
http://www.ni.com/getting-started/set-up-hardware/instrument-control/usb-connect
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US
 https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KvOSAU
(9,171 Views)
Thank you,
I've solved following this article https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US/
(9,144 Views)
