NI MAX does not recognize an instrument connected via USB
Hi!
I'm trying to develop drivers in LabVIEW for an USB instrument. My problem is that on NI max, I do not see the instrument. In Windows devices (windows 7 - 64 bit), it is recognized as: USBIO controlled devices - USBIO Device: VID = 03EB PID = 2FFB, and with its software installed on the PC works correctly. How can I solve?
Thank you
(9,201 Views)
Accepted by topic author sepp974
These are some results after searching for "ni max usb devices" using Google.  They should point you in the right direction.
http://www.ni.com/getting-started/set-up-hardware/instrument-control/usb-connect
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US
 https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KvOSAU
(9,165 Views)
Thank you,
I've solved following this article https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US/
(9,138 Views)
