NI MAX not seeing Agilent 34970
Essence of the problem is that I'm having difficulties getting NI MAX to see an Agilent 34970.
I'm setting up a new computer to run a LabView runtime application. Thus far, I have done the following:
Install LabView runtime 15.0
NI-VISA runtime 15.0.0
NI-DAQmx runtime 15.0.1
NI-DAQmx 15.0.1
Keysight Connection Expert
I tried to download the agilent 34970 driver located here: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=014F4CD7EF78136AE0440003BA7CCD..., but the directory doesn't exist that I'm supposed to copy the files to.
In device manager the Agilent shows up as a CP2102 USB to UART Bridge Controller.
(2,662 Views)
Accepted by topic author RansomDE
Are you using a USB to serial adapter to connect to the serial port on your device? If so, have you installed drivers for the USB to serial adapter?
(2,644 Views)
Yep that's all it was. Thank you!
(2,623 Views)
