Signal manipulation, cannot find express VI replacements
For proprietary reasons, I can't post the VI I'm talking about here but I will attempt to describe it. I have a VI from an old LabVIEW program, this program used express VIs to manipulate signals (waveform data). One of the express VIs was "arithmetic" which would add two waveforms together mathematically. I don't see this anywhere in the express pallet of LabVIEW 2016.
Also, the same "amplitude and level" and "distortion" VIs exist in the current express pallet but "distortion" doesn't have an output for fundamental frequency (the original 'distortion' express VI outputted this value as a scalar DBL).
The use of the express VIs here just seems unnecessary, I'm also thinking about just scrapping this legacy VI and rewriting it using the standard DAQmx library.
(3,023 Views)
Yes!!!
Bob Schor
(3,000 Views)
Thanks. Let's say I have an analog input from 8 channels. If I set up my DAQmx task to read N samples N channels, how do I parse that data that comes out? The DAQmx read function only outputs 1D waveform array, shouldn't it be 2D? (one row of data for each channel?)
Or do I need to parse based on number of samples? i.e.
0N - 1N = channel 1 data
1N - 2N = channel 2 data
This is all kind of confusing because some of the VIs I need to use like (express vi: "filter") outputs dynamic data.
(2,982 Views)
Oh wait, I think I've figured it out. Each element of the waveform array contains ALL the sample data for a given channel.
So array[0] contains all the sample data for channel 1...right?
(2,979 Views)
Accepted by topic author TestEngineer11
You get to Have Your Cake and Eat It, Too.  [Or at least I have this choice ...].  When you configure the DAQmx Read for N Channels, N Samples, you can choose 1D Array of Waveforms (where each Waveform holds all the sampled data for a channel) or 2D Array of Dbls (where the first index is over Channels, the second over Samples) (unless I got that backwards).
Bob Schor
(2,974 Views)
