NI Modbus Library
@LV_Pro wrote:
Sorry, the error I am getting is "Error 538182 "Modbus Error: Illegal Data Address"....My issue is trying to figure out what the new ones, Micro820, (apparently AB is/has phased out the MicroLogix 800 series) aren't happy with, what a valid address for it might be.
The manufacturer should have provided a "Register Map" that lists the proper address(es) for the values you need to read/write and when reading registers how to scale the integer(s) to the proper numeric value. Without that you are kinda hooped.
=== Engineer Ambiguously ===
Message 11 of 18
(1,506 Views)
Are there any protections in place to prevent reading some addresses on your new system? Can you read ANY addresses? I'd try writing a program to scan them individually, one at a time, and see when/if it throws an error. Or, like someone else mentioned, get a general Modbus tool to make sure the thing will actually talk to you.
Also, I second the advice to sniff the packets. Use NI IO Trace if you can, or try HHD Device Monitoring Studio (if it's serial).
Message 12 of 18
(1,490 Views)
As I recall, some devices will let you read any number of registers at once, but some will complain if you try to read more than what is specified as one entry.
IE if there are two floats at registers 20,21,22,23, some devices would let you read all 4 registers at once. But some will throw an error if you try to read more than 2 registers from each location.
Message 13 of 18
(1,483 Views)
To me, this sounds like a missing configuration on the PLC side. Do you maybe need to map values to modbus registers?
Message 14 of 18
(1,456 Views)
I don't remember ever running into anything like that, but it is very common to get the illegal data address error when you try to read any address which isn't explicitly supported by the device (so if the documentation tells you there are values only at registers 22 and 23, then trying to include registers 21 or 24 in a read command will result in an error). With the off-by-one error, it becomes easier to run into this issue. That's why I suggested starting with a generic program and just looking at the actual values which can be read (and mainly getting the documentation).
The other thing which exists is that Modbus has a 125 registers per read "limit" (which like other things in Modbus, is somewhat fluid). That said, I doubt this is the issue in this case (and I don't know which error it would return).
___________________
Try to take over the world!
Message 15 of 18
(1,448 Views)
Should is the keyword here. Some manufacturers want their users to stay with their own tools and hide or obfuscate such information by various means. I would imagine that A-B, aka Rockwell Automation believe that their tools are so superior that anybody trying to use something else must be nuts. They may advertise Modbus capabilities in the marketing literature, but make it harder then necessary to use that since using their integrated programming environment and HMI software is SO MUCH better to use (also for their bottom line of course 😀).
Other manufacturers simply put such functionality behind a license key that you have to purchase separately if you choose to refuse to use their own tools!
Rolf Kalbermatter  My Blog
Message 16 of 18
(1,440 Views)
@LV_Pro wrote:
Sorry, the error I am getting is "Error 538182 "Modbus Error: Illegal Data Address". Understand, this program has worked, literally for years, on Allen-Bradley MicroLogix 800 series PLCs. My customer, the system constructor, switched to an Allen Bradley Micro820, which, despite the similarity in names, is not in the same hardware family. My issue is trying to figure out what the new ones, Micro820, (apparently AB is/has phased out the MicroLogix 800 series) aren't happy with, what a valid address for it might be.
My guess is that they remapped the Modbus addresses more or less completely to a different range due to the fact that the native register map probably got completely redesigned, if it is really a very different device.
Seems the MicroLogix820 is in fact even designed by a third party, so it is even more likely that the internal native register map was completely redesigned from scratch, and the according Modbus wrapper probably does a very different mapping to Modbus register numbers (or even may require some license activation to be able to use it).
Message 17 of 18
(1,421 Views)
Accepted by LV_Pro
So, forehead slap, I found the issue.
The two devices use different addressing systems, The MicroLogix device uses an address like 30001 to read from a register, with the LabVIEW Modbus Read Input Register.vi
But with the Micro820 series that address is invalid, it expects an address of 0 for the same register.
I ended up writing a small vi that allowed me to repeatedly read while changing addresses and number of inputs, watching the transaction with Wireshark, which I couldn't do with the actual program.
So the bottom line is that, at least in my case, the major change was to identify what it wanted as a valid address. I did, in working on this, find a bug in the screen that allows the operator to choose which tagname was associated with a specific graphical display, apparently it had never been used since the initial set of the program, 14 years ago.
Thanks for everyone's assistance!
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 18 of 18
(1,065 Views)
