NI MyDaq Analog input always returning error -201381
Hi all,
I have a mydaq which always returns error 201381 on random timestamps (overcurrent protection kicked in) when trying to read any analog input (ai0/ai1).
This is even the case when nothing is connected. Could it be the ADC is broken?
What could I do/test to try to resolve/pinpoint the issue?
thx
(108 Views)
Could you please attach photo and/or the VI's you are referencing to the post? Also describe all the physical connection you have to your device with nothing plugged into the mydaq.
(79 Views)
A few suggestions:
  • What version of LabVIEW (year and revision, bit-ness) and Windows are you using?
  • MAX is your friend.  Open MAX, find your myDAQ, and open a Test Panel.
  • Describe what is wired to what.  You say "ai0/ai1" -- what does this mean?
  • Are you recording single-ended or differentially?  Describe what is connected to each Analog Input line (or say they are "floating in the breeze").
  • What happens if you put a resistor (or, alternatively, a wire) across the two inputs you are using?  With a resistor, do you pick up A/C "noise" at 60 (or 50) Hz?
I have a myDAQ at home.  I can try it out this evening (if I remember).  I'll be using Windows 11 and LabVIEW 2024 64-bit.  [Oops -- it might not run with 64-bit LabVIEW ...].
Bob Schor
(66 Views)
