10-02-2011 08:39 PM
Hi everone,
I need to know what is the scaling equation that need to put in NI OSI explorer in order to get a correct reading from the FBG sensor?
10-03-2011 01:26 AM
You'll have to explain somethings without using TLA's (three letter acronyms).
What is OSI explorer?
What is an FBG sensor?
10-03-2011 01:34 AM
Hi Ravens,
Thanks for reply, NI OSI is a driver for NI PXIe-4844, it stands for Optical Sensors Interrogator for Fiber Bragg Grating.
in NI OSI there is a scaling formula to write to convert the wavelength reading to an engineering unit such as microstrain etc..
I need to know what is difference between nominal wavelength and nulled wavelength.
your help appreciated.
Aneece
10-03-2011 07:33 AM
What measurement are you trying to make, temperature, strain or something else? It has been a few months since I have used the OSI explorer, but I beleive the the nulled wavelength allows you to set an initial wavelength value for the FBG - thus allowing measurements to be taken from this value. Nominal wavelength is just the wavelength value as is. If all you want is wavelength then the equation should be 1*x.
10-04-2011 03:30 AM
Thanks Chris,
Yes I want to measure strain & temperature , I got the equasion thanks a lot.
Aneece
