NI PAL nimxs.exe error with jpeg
Hey all - having issues getting MAX to see my chassis and observed this at startup.  I don't know if this is the symptom, but I can see my camera under devices.
I read thru some forum posts indicating that someone may know where I can start re-installing.
Please see attachment - thanks for any help.
VG
Message Edited by VisionGumby on 01-29-2008 02:10 PM
(3,018 Views)
Followup: tried connecting to MAX and get the attached error.  Reboot of all systems did not help.
(3,007 Views)
Hi VG,
I read your post and looked at the JPEG files you attached.  You seem to be experiencing a MAX database connection error.  Please follow the steps in this Knowledge Base to correct it.
I hope this helps!
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(2,976 Views)
Thanks for the link Ima - my problem was a combination of items 2 and 4.  Problem solved, productivity soaring.  Smiley Very Happy
VG
(2,966 Views)
You are welcome!Smiley Happy
Ima
(2,948 Views)
