VISA Resource Name Problem
I'm having some trouble getting connected to a power supply from an embedded controller (NI PXI-8196) via the VISA TCP/IP using Labview 8.5.
The error code that I am receiving is -1073807239.  I believe this error is caused by an error in my VISA resource name.
I have made the appropriate additions of TCP/IP resources in MAX using the "auto-detect of LAN instrument" feature, however when trying to access the test panel, I get an "unable to open session" error.
Note: I have gotten this to work prior to an upgrade to Labview 8.5 when using Labview 8.2.
I'm all ears for any suggestions.
(2,900 Views)
Hi gerbalg,
We can continue working on this issue through the service you created at ni.com.  If anyone else has any input on this issue please feel free to respond.
Andy L.
(2,862 Views)
