NI-PCI 1408 Framegrabber with JAI CV-M1 Camera
We have a problem running a JAI CV-M1 camera with a NI-PCI 1408 framegrabber
under Windows NT4.0 (SP 6).
In the Computer there is installed:
NI-PCI GPIB card
NI-IMAQ PCI 1408
NI-PCI 6024E
The GPIB card and the Input/Output card (PCI 6042E) are working fine.
The framegrabber (PCI-1408) does not work well with the camera (JAI CV-M1).
If I select the IMAQ PCI 1408 card in the Measurement and Automation
Explorer and there e.g. Channel 0 I can choose between various drivers for
the camera. If I choose the drivers provided by our supplier I do not get a
image if I select "Snap" or "Grab". Instead I get an error message:
" can't lock on video source" or sometimes: "
wait timed
out - aquisition not complete".
The only way to produce an image is to select "Area Scan" as a driver and
"Grab" - if I choose "Snap" I get " wait timed out -
I cannot get any image within LabView 5.1.
The following error messages I get in the event viewer of Windows NT:
* "The description for Event ID ( 11 ) in Source ( PCIIMAQ ) could not be
found. It contains the following insertion string(s): , BAR[3]: Phys
MemBase:0 MemSize:2."
found. It contains the following insertion string(s): , BAR[2]: Phys
found. It contains the following insertion string(s): , BAR[1]: Phys
MemBase:43000000 MemSize:10000."
found. It contains the following insertion string(s): , BAR[0]: Phys
MemBase:43100000 MemSize:4000."
What can I do to get the system run?
Thanks a lot,
Gerd Simons
(2,986 Views)
Gerd,
The camera that your refer to is a progressive scan camera. It is probably
in the non-interlaced mode. In this case you need to set the board for
frame mode, in measurement and automated explorer. There may be a setting
on the camera for interlaced mode. This would work if the board were set to
field mode.
Good Luck,
Bill Magiske
simons@ifm.mavt.ethz.ch wrote in message <3a0c091f@pfaff.ethz.ch>...
>Hi,
framegrabber
>NI-PCI GPIB card
>NI-IMAQ PCI 1408
>NI-PCI 6024E
>wait timed out - aquisition not complete".
>Thanks a lot,
>Gerd Simons
(2,986 Views)
