NI-PXI 4472 and 4472B, AC - Coupling Hardware information.
I need to know what kind of hardware is implemented in 447X DSA boards and how works this.
According to the manual, 4472 has a cutoff frequency in 3.4 Hz, and 4472B in 0.5 Hz (for AC- Coupling). What is the main reason to have this two DAQ alternatives?.
Where can i find information related to this?, Hardware, implementation, etc.
Is there any other difference between 4472 and 4472B?
Any information will be helpful.
JFT
(3,341 Views)
JFT,
Thanks for making your post. The question that you posed, regarding the differences between the 4472 and the 4472B, is actually a relatively common question.
As you noted in your post, "According to the manual, 4472 has a cutoff frequency in 3.4 Hz, and 4472B in 0.5 Hz (for AC- Coupling)." This is actually the only difference between the two devices. In order to understand the reason for the difference between the two boards, I will quote 4472B's product page which states that:
"The National Instruments PXI-4472B, an extension of the NI 4472 family, is optimized for vibration and low-frequency AC measurements."
Basically the 4472B is a 4472 board specifically designed to be able to measure the 0.5 - 3.4 Hz signals that the 4472's filters remove from the signal. Otherwise it is identical to the 4472.
I hope that helps to clarify. Please post back if you have any questions that this forum can help you with.
Jed R.
Applications Engineer
(3,320 Views)
Ok, thanks a lot.
And about the Hardware, where can i find information?. I need to know, for example, what kind of capacitor or resistor has the filter, or if it has any kind of digital "treatment" or something unusual...
Thanks again,
JFT
(3,310 Views)
