NI PXIe-1073 Triber Problem ! Driver Code 31
Hi there!
Actually, we get a problem during the installation of the NI PXIe-10735-Slot 3U PXI Express Chassis with AC - Up to 250 MB/s  Driver (Code 31), with Windows 7, 32Bits.
We used the Version 3.0.2 availble in the original CD Platform-Service but we think that the Driver was not correctly installed, and the problem consist on the PCI-PCI-Bridge, PCI-Express Standartupstreamswitchport.
We check out if there is any updates but no results 😞
What shall we do ?!?
Thank's in advance...
Yours,
(2,575 Views)
Hi Tony,
maybe the new version of the PXI Platform Services helps to solve the issue:
PXI Platform Services 3.0.3 - Windows 7 32-bit/Vista 32-bit/XP 32-bit/Vista 64-bit/7 64-bit:
http://joule.ni.com/nidu/cds/view/p/id/2952/lang/en
If not please send me a MAX-Report of your computer and an extra one of the PXI-System under network devices:
1. Start -> All Programs -> National Instruments -> Measurement & Automation
2. File -> Create Protocol -> Technical Support and My System -> next -> next -> choose a path -> next -> finish/close.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(2,555 Views)
